Weird Squeal - Maintenance and Repair Forum
Weird Squeal
Saturday, January 27, 2007 9:57 AM
I had a new GM OEM belt put on my 2000 Z
My old belt would squeal when wet or on occasions when it wasnt under load it would just squeek a bit
So i finally got the new belt on
The next day i pushed my rear defroster after starting the car and turning on the headlights and such and a loud squeal started and wouldnt stop, i turned off the car and re started it
This time i didnt use the rear defrost and it didnt squeal
Anytime i overload the system it squeals like mad Headlights Blower Motor Rear Defrost i can make it squeal
Also when i start the car i get a miny squeal for about 2 secs
Any ideas?
Re: Weird Squeal
Saturday, January 27, 2007 10:19 AM
I would suggest belt dressing but from what i hear it's not good for a belt but did you happen to get coolant or and oil or any other liquids on the belt when changing it? If so I had the same problem and I just had to bit the bullet and get a new one because i spilt like 5 drops of coolant on it. but if you want get some belt dressing and just a quick spray on both sides of the belt will work. (did that with winter beater and worked great with no problems 3 months now) so I guess belt dressing was good for me just dont use a ton because it can get messy.
Project Yellow Blur Is Under Way ! ! ! ! !
Re: Weird Squeal
Saturday, January 27, 2007 12:58 PM
Weak Belt Tensioner?
Re: Weird Squeal
Saturday, January 27, 2007 1:08 PM
Mike wrote:Weak Belt Tensioner?
x2
i wouldnt recommend belt dressing at all....you will create more probelms than you have
Re: Weird Squeal
Saturday, January 27, 2007 5:46 PM
Sounds like a weak belt tensioner and when you put a load on the alt the belt is not on tight enough and slips.
My car--->http://www.cardomain.com/ride/2569452
Re: Weird Squeal
Saturday, January 27, 2007 5:56 PM
Weak tensioner eh
Is there a way to test that?
When i put the new belt on we had a hard time getting it on cause we couldnt get enough slack from the tensioner tool
Re: Weird Squeal
Saturday, January 27, 2007 8:20 PM
When you put the new belt on, to release the tension, did you turn the tensioner tool Clockwise or Anti-clockwise?
Alont
Re: Weird Squeal
Saturday, January 27, 2007 8:31 PM
I think he brought it toward the front of the car
Re: Weird Squeal
Sunday, January 28, 2007 5:44 AM
Tensioners can ONLY be turned CLOCKWISE, turning them counterclockwise will damage them.
Re: Weird Squeal
Sunday, January 28, 2007 8:56 AM
Really not sure if he only turned it Clockwise
Ill have to go get it looked at by a dealer
Re: Weird Squeal
Monday, January 29, 2007 3:28 PM
According to mechanic it is the Belt tensioner
Re: Weird Squeal
Tuesday, January 30, 2007 5:07 AM
Thanks Rob S--you said:-
[Tensioners can ONLY be turned CLOCKWISE, turning them counterclockwise will damage them.]
sUiCiDe had said:-
[When i put the new belt on we had a hard time getting it on cause we couldnt get enough slack from the tensioner tool]
This is what made me think the tensioner had been damaged by attempting to turn it the wrong way--the mechanic seems to have confirmed this
Alont
