DO CLICKING SOUNDS EQUAL STARTER - Maintenance and Repair Forum
Tuesday, January 09, 2007 11:21 AM
hey guys had the cavi in storage for about 3 months now pulled it out put a new battery in (upgraded to a yellow top) and when i try turning it over it cycles a couple of times and then clicks. after about 15 min i finally got it to start. but before i drop the cash on the starter i wanted to make sure that there was nothing else i could look at
thanks
'spit chew hits soldiers boot'
"thats a real nasty habit you got there"
"this stuff will make you a sexual tyransaur just like me"
jesse the body ventura in Predator
Re: DO CLICKING SOUNDS EQUAL STARTER
Tuesday, January 09, 2007 11:30 AM
Try banging on the starter next time it does that. If it works after banging on it, then yes, its the starter. Otherwise you could be missing teeth on the flywheel/flexplate. If thats the case, putting it in gear and rolling it a bit will cause the starter to not click.
