My back up lights aint working ... the fuse isnt blown and the bulbs are good ... i need help
turn your front wheels all the way to the right. look behind the driver side front wheel, and you'll see two wires going into your transmission. this is the reverse light switch. replace it, and you should be good.
if you search the maintenance forum, you should find a part number for it. I'm not sure if it's a dealer only part though.
Desert Tuners
There needs to be a sticky on this subject.
