need help! please - Maintenance and Repair Forum
need help! please
Wednesday, December 20, 2006 11:01 PM
my problem on my 98 z24. i have a p0300 code, and at idle it jumps from 500 to 1500rpm it revs fine until it goes back to idle then it trys to die. i know the code is a multiple cylinder misfire. Also my ets light now comes on all the time. its been in the shop 3 times and noone can figure it out . any help would be appreciated
Re: need help! please
Thursday, December 21, 2006 12:29 AM
How long has it been since youre car has had a tune up?. Could also have a coil pack acting up. I would look into that area for misfire. I am pretty sure that will narrow it down to the problem.
Thursday, December 21, 2006 6:30 AM
4 about 3 months now and i changed the plugs but i put auto-lites back in it
Thursday, December 21, 2006 6:33 AM
any ideas on the ets light the speedo also is tweekn out until i turn the car off and back on the n its fine for a few miles
Thursday, December 21, 2006 10:35 AM
I had the same code on my 97 sunfire gt along with one more. I changed gas caps, and changed the coil pack. The check engine light didn't go off that night, but the next day I was getting gas and when I came back out the light shut off and then the ets started working properly too. Don't know if it will help you or not, but that's how I fixed mine. And it has been fine for a week or so now.
Thursday, December 21, 2006 10:25 PM
k thanks 4 your help. it started when i had a low class shop replace the motor. he said it ran perfect when i picked it up and it didnt but ever since then it has been a money pit. its worse than my 69 chevy drag truck it still gets 28 mpg so i have no clue what it is im about ready to trade it off!
Friday, December 22, 2006 2:22 AM
Is youre car acting up while stop and go driving?. You could have a problem with youre (VSS) speed sensor. I could be dirty or starting to fail.
Friday, December 22, 2006 7:54 AM
ya it acts up all the time
Friday, December 22, 2006 8:42 PM
where is the vss located and how do u go about cleaning it. also could the prob be from timing cause they had to replace a broken timing chain housing? There is some sort of noise coming from that area of the engine... does it matter what brand of plugs i put in it cause i was told that it does make a difference
