Instructions on the bottle :
A. RMI-25 is used in new vehicles to prevent corrosion
and in used vehicles to clean the system and prevent
corrosion.
B. RMI-25 is non-toxic and safe for all metals, metal
finishes, aluminum engines, skin and eyes.
C. Lubricates water pump seals and heater control valves.
Retards electrolysis and corrosion erosion.
D. Dosage - 8 oz. per 5 gal. cooling system. Maintain
every 15,000 miles (300) hours.
E. Corroded systems are cleaned in two weeks (15 hrs.)
of normal driving.
F. Radiator draining and refilling aren't required.
Excessive corrosion floating on the surface of a cool
radiator can be flushed by overflowing the radiator
at the cap or recovery tank.
G. In extremely rusted systems where rust penetration
has occurred, good cleaning action may reveal a leak.
Quality stop-leak is recommended to seal such openings.
If leakage persists, see a radiator specialist.
H. Contains fluorescent leak detector.
Searching the web there were lots of comments, all
good, and it was especially recommended for users
of DexCool.
Check it out.
Yeah. I wonder how many people would read that and not see all the contradictions.
CTS, you may want to reconsider your comment...
This product has been in use for many years...
Originally for large diesel / truck applications...
No reason it should not help us, also...
Why don't you check it out ?
Leland Sparks wrote:No reason it should not help us, also...
But, you shouldn't. Your better off properly flushing the system and using new fluid. If theres corrosion the parts should be replaced. So the additive is pretty much worthless IMO.
-Chris
