washer fluid jets not spraying - Maintenance and Repair Forum
Wednesday, November 29, 2006 4:28 PM
As the topic says, my washer jets are not spraying....i filled up the tank and tried for a while but no dice.... any suggestions?
Re: washer fluid jets not spraying
Wednesday, November 29, 2006 6:05 PM
Ah yeah.
Do you hear the pump running?
Is the fuse blown?
Are the jets clogged up with frozen ice/snow?
Thursday, November 30, 2006 4:37 AM
^ x2, and adding hoses all hooked up? Kinked/ broken/crimped?
Thursday, November 30, 2006 7:49 AM
ive seen many cavaliers have rips in the hose right where it turns around the battery tray...might be a good place to start looking.
have someone spray it while you look under the hood for sprays/leaks, etc...make sure the pump is running, check the fuses...if not, then you might just have to replace the nozzles.
this useless post brought to you by the alcoholic known as LUNDiS
Thursday, November 30, 2006 1:25 PM
sorry to get a bit off topic here but how do you adjust the nozzles my right one just squrts a little bit where as my left one works great how can i fix the other one?
Thursday, November 30, 2006 8:14 PM
^^^^ more than likely your right nozzle is clogged, or the hose leading to it is crimped, reducing pressure to the nozzle. Both nozzles work off of one pump with a "T" splitter directing flow to the nozzles- there really is no way to "adjust" the flow to one nozzle, excepting the possibilities I just mentioned. good luck.
I may not be the sharpest crayon in the box, but at least I'm a pretty color
Thursday, November 30, 2006 9:19 PM
ok cool man i will have to check the lines out and stuff then thanks! but how can i uncloge it if it is?
Friday, December 01, 2006 5:26 AM
You can sometimes use a needle, if your careful to unplug it. However they cost like $6 at the dealer, I always just replace them, for one it is a safety concern.
Sunday, December 03, 2006 12:07 PM
well why didn't i think of that? lol.... took the heat gun to the nozles and boom it works again... just some ice in there i guess
Thursday, December 07, 2006 9:33 AM
same thing is happening to my g/f's95 cav....the motor isn't running, but which fuse powers the motor?
