checking fuel injectors? - Maintenance and Repair Forum
Friday, November 24, 2006 11:27 AM
i have a 2.3 and it skips, ive changed the coil pack housing, spark plugs, and fuel filter. could it be the fuel injectors?
Do the fuel injectors ever need to be changed? ive already added fuel injector cleaner and that helped a little but it still does it. a answer ASAP would be helpful thanks
"HONDA" tech wana-be
http://www.gadomestics.com/
Re: checking fuel injectors?
Friday, November 24, 2006 3:45 PM
Okay skips, you means misfires?
When does it misfire all the time, idle, under load, all speeds, when cold, when hot all the time. When did it start?
A littel more info would be nice.
Fuel injectors, go bad but not all at once.
Could be a fuel issue, plugged injector, stuck closed.
I wont be able to help out until more info is posted.
Friday, November 24, 2006 4:52 PM
It misfires when its cold, sometimes at idle, when you lightly get on the gas just to maintain speed.
