ok I know this is going to sounds stupid. anybody got instructions on how to change the pads on an 02 sunfire? i'm want to do it myself. Thanks
Jack front of car up, place jack stands underneath it.
Take wheels off.
You will see something similiar to this. The part that the guys hands are on is the caliper. Un-bolt the caliper and pull it off. Take the pads out of the caliper bracket. Slide the new ones in.
You will want a brake piston compressor tool:
Take one of your old pads, place it between the piston and the tool, and push the piston in all the way. Stop when you feel alot of resistance, or until the piston is almost flush with the caliper.
After pushing the piston in, place the caliper back in place. After doing both sides, PUMP THE BRAKES IMMEDIATELY. If not, you won't be able to stop on the first try of pressing the brakes if you try to drive it.
Take the car up to 65mph, and firmly press the brakes until you stop. Drive for a mile or so and do this once more. This is seating your pads into the rotor, will make you stop much better.
Any more questions or anything, just PM me.
1983 Camaro Z28
anybody know what tool i need to get the 2 bolts of the back of the calipers out? i think it's star shaped
Torx #50
Also, you can use a C clamp to compress the caliper.
Gilles
2.3 Ho
you can use an old pad and the c tool to push the piston in aswell.
Ah, sorry about that. I know that my J used a 3/8 drive allen socket for the caliper bolts, didn't know that they changed it for 02 Fires.
1983 Camaro Z28
s'all good. thanks for the update. really appreciate it
