engine re-install...need help....asap... - Maintenance and Repair Forum
Saturday, November 11, 2006 12:02 PM
i'm about to reinstall in motor back in my cavy....quick question.....do i set the crankshaft at the 15 degree mark before TDC....before i start the motor???.....thanks....
WHEN I'M GOD, EVERYONE DIES
Re: engine re-install...need help....asap...
Saturday, November 11, 2006 3:42 PM
uh... no.
Just put the engine in the car, and hook everything up.
Saturday, November 11, 2006 4:03 PM
Anybody else fear for that car's health?
If you took the timing chain off it has alignment pins so you know how to put everything back. Otherwise the computer controls advance....
Saturday, November 11, 2006 11:04 PM
i wasn't reffering to the timing between the crank and the cams.....that i already know......lets try this another way....i rebuilt the motor from the ground up....TIMING IS CORRECT (i have a haynes manual)....now after everything is put back together (CORRECTLY).....do i leave everything at TDC???.....i only ask because of that 15 degree mark on the timing chain housing cover...and i haven't seen anything in the book about it.....
Sunday, November 12, 2006 12:29 AM
Just put the motor in the car... no need to worry, it doesn't stop at the same place every time...
Sunday, November 12, 2006 12:46 AM
thanks...
Sunday, November 12, 2006 9:59 AM
yah... doesnt matter so much on computer controlled veicles... only on initial startup with a ditributor engine... you need the timing close, but not spot on. our cars, they're smart (kind of).so long as the cam is timed with the crank, it doesnt matter where in the cycle it is, just bolt that thing on, stir, and enjoy.
