Bent Rod - Maintenance and Repair Forum
Bent Rod
Thursday, November 09, 2006 8:29 PM
I noticed a very loud knocking noise coming from inside the engine today. As I drove longer, it got louder. When I push the car to full throttle, it feels like half throttle. I called a few places all of which told me that one of the rods was most likely bent/warped. A mechanic hasn't actually looked at it yet. This is just going off of the symptoms given to them over the phone. I was quoted 1000 dollars for a new camshaft. The car is only worth about 3500, but can't afford another car at the moment. My question is, Is this problem common to J-body's? Also, Would I be better of with a new motor all together?
Re: Bent Rod
Thursday, November 09, 2006 8:31 PM
Sorry, meant to say crankshaft not camshaft.
Re: Bent Rod
Thursday, November 09, 2006 9:19 PM
Well... I've never met a mechanic who could diagnose a car over the phone... so he must be really good! Heck... even some times when I see a car, I don't get it right off the bat... and I know J-bodies pretty well... so.... I'd say you might want a second opinion!
A crankshaft isn't going to cost $1000... and if your crank is gone, it's going to be one of the few I've ever heard of. Now, throwing the #3 rod bearing... much more likely... but you'd probably have a hole in the side of the block to match it... so... yeah, I'd they're just pulling numbers out of thin air...
Re: Bent Rod
Thursday, November 09, 2006 11:38 PM
got my crank from autozone... $230
Re: Bent Rod
Friday, November 10, 2006 2:20 PM
most shops will try to screw you pretty bad if they think you don't know what you're talking about. I thank most shops high labor rates for giving me the incentive to tackle most projects myself.
2001 2 door five speed 122k.
custom steering linkage pop
2000 s10 (THE WORKS)
Re: Bent Rod
Friday, November 10, 2006 10:56 PM
IF"" #3 is gone, just find a new motor @ the wreckers for a decent price out of another 99. A decent shop will charge 400 to 500 to drop the new motor in, your looking @ 800 to 1200 depending on how much you pay for the motor itself, I do know getting a motor in the States is a hell of a lot cheaper then what we pay up here in Canada.
Good luck.
My Cav
I give up...
Re: Bent Rod
Saturday, November 11, 2006 4:17 PM
Time for another opinion.
If he meant push-rod, then there are no push-rods in that engine.
If he meant connecting rod, then I've never head of a bent/warped one and would definitely need to see it to believe it.
Like Lenko said, breaking them and spinning bearings happen (especially on #3 for some reason).
I've never heard of a crank going either (unless something else damaged it).
Might be a keeper came lose and now the valve is jammed into the head, but that's a pretty wild guess.
