rough idle - Maintenance and Repair Forum
rough idle
Tuesday, August 22, 2006 5:14 PM
Anyone else have this problem. Car runs fine but when stoped at a light it seems to get a rough idle. Tach sits at around 600 but seems to be just rought when sitting in traffic almost like a hesitation.
plugs look good.
2002 Sunfire auto with 65k kms
Re: rough idle
Tuesday, August 22, 2006 7:37 PM
600 rpms is where it should be.
Re: rough idle
Tuesday, August 22, 2006 7:42 PM
bsquared, you may want to pull those sparkplugs again...
The ones that came in my 2002 Cavalier were weak...
Got rid of them at about 8,600 miles...
What a difference !
Re: rough idle
Wednesday, August 23, 2006 3:04 AM
put some ac delcos in if there isnt already.. 8600 miles is dumb to replace plugs..
Clean your t/b
change air filter
maybe fuel filter depending on mileage
does the car still hesitate if u put it in neutral?
Re: rough idle
Wednesday, August 23, 2006 9:40 AM
<<put some ac delcos in if there isnt already.. 8600 miles is dumb to replace plugs>>
If there is a weak sparkplug, any engine will run rough....
It doesn't matter if it has just a few miles on it...
Re: rough idle
Wednesday, August 23, 2006 11:04 AM
Jonathan, sparkplugs from any manufacturer are subject to
defects...
A new set doesn't always cure what's wrong..
Re: rough idle
Wednesday, August 23, 2006 11:48 AM
when stoped the idle speed is ok but almost as if just one plug was off and not firing right. Anyway checked the factory plugs and they look good (as said i ~65ooo km = 40ooo mi). Air filter is good and clean. Next thing would be fuel filter but no reason to be that as car starts ok adn runs fine (acceleration and all). And to answer Jonathan's question... yes if i put the car in N when stoped still rough. Anyone else have this problem?
Re: rough idle
Friday, August 25, 2006 4:45 PM
PCV !!!! same symptoms
911 ... got fire?
Re: rough idle
Friday, August 25, 2006 7:54 PM
if you have the 2200 (not the ECOTEC) , then its completely normal, at the low rpms the engine vibrate allot more then when you are moving on down the road. stick it in N and put the RPMs up to about 750 -1000 you will see it smooth out
AC Delco platinum plugs are what comes standard in the car.
Re: rough idle
Wednesday, October 25, 2006 6:58 AM
That whole sputter stuff. Do you notice that your car barely runs on 4 cylinders after you come back from a long drive? Like a 45 minute drive, put it in park and then she almost stalls. Start er back up. She barely wants to start and when she does a puff of black smoke comes out? Try replacing both your oxygen sensors. Try to get BOSH sensors. There some of the best quality.
Re: rough idle
Wednesday, October 25, 2006 7:28 AM
I've had idle issues with Bosch platinum plugs, 2 sets, car would never idel well.
Put in Champion platinums, car is like new again. Both sets of the Bosch's were
re-gapped, cleaned, several times, to no avail.
