Just a quick question guys. I have been doing some research on here and you are suppose to put oil(?)/freon in the compressor before you install it? is this right and if it is how would i do this?
Thanks
Dan
The oil goes in with the freon, usually freon kits have the lube included. It's not really oil, it's just called that for simplicity.
So then I don't have to put anything in the compressor when i put it in, and the oil(lube) just goes in when I fill the system again with freon? I was under the impression that I had to add something to it before I connect it to the hose
