just what it says im curious if anyone knows how to adjust the parking brake mine got really lose when i did my rear brakes.
thanks in advance
The one, the only, ME.
can adjust the shoes just not the parking brake. my parking break doesnt grab as tight as it should it, like the cable is stretched but its not.
and thats not written as being a smartass heh heh i appreciate the effort
adjsuting the shoes does adjust the ebrake. you adjsut it so the shoes are closer to the drum. thus when you pull the ebrake it takes less for the shoes to make contact. trust me....i swear it works
I may run 18s, but I can do your taxes in 10 seconds flat.
alright ill give it a try i couldve sworn when i did the shoes they were damn close. plus i was thinking it was like other models where there was a seperate adjustment for it.
thanks ill let you know the out come
There's an adjustment pawl inside the e-brake mechanism. If you yank it up and down a few times it should tighten. If it's not tightening, the pawl spring could be out of place... or it's stretched the cable too much to adjust enough...
