Winter, Lowered, Body Kit, Flat Tire = ? - Maintenance and Repair Forum
Thursday, October 19, 2006 9:58 AM
Just wondering what others have thought of in this situation. My car sits about 4 1/2"s off of the ground and I'll be driving it in winter. I have a couple of pieces of cut up plywood and two 14" long 2x4's cut sitting in my trunk in case I get a flat. I pray to God that I never do, since if I did get a flat I think that my body kit would get trashed.
What have others done for a flat tire situation?
Re: Winter, Lowered, Body Kit, Flat Tire = ?
Thursday, October 19, 2006 10:03 AM
Move somewhere that it doesn't snow?
I think that is why most people that live in places like that have a winter beater.
Thursday, October 19, 2006 10:06 AM
ur scissor jack should work fine......i would assume
Thursday, October 19, 2006 10:49 AM
move down here (South Florida).....always sunny and shiny!!!!! too hota dn humid sometimes...
CaviFL45
Thursday, October 19, 2006 10:54 AM
carry fix a flat, a portable compressor and a scissor jack...problem solved unless the tire shreds...then ur @!#$ royally
I may run 18s, but I can do your taxes in 10 seconds flat.
Thursday, October 19, 2006 10:57 AM
bodykit and winter spells disaster..mine died over winter..as for a flat..the stock jack works great...thats what i use to get mine up in the air..phil
Thursday, October 19, 2006 1:42 PM
fix a flat is not intended for z rated tires (check the can)
your kit wont be trashed if you get a flat. is your sidewall bigger than 4 1/2"? if you get a flat just drive it up on the blocking and then change it w/ the factory jack. w/ my car lowered like 2 1/2" inches i can still get the factory jack under the car and clear the side skirt still
Thursday, October 19, 2006 2:45 PM
i think what he's worried abotu is drivign on the donut....not just getting the flat
Thursday, October 19, 2006 8:54 PM
You could always go to like Autozone or something and pick up the coil spring boosters. They are rubber blocks that push spring coils apart...its a temporary lift, basically...
Thursday, October 19, 2006 8:57 PM
89Sunbird wrote:You could always go to like Autozone or something and pick up the coil spring boosters. They are rubber blocks that push spring coils apart...its a temporary lift, basically...
hats is horrible for your springs
Thursday, October 19, 2006 10:03 PM
A. winter beater
or
B. remove body kit/rims and roll around stock for winter (like i do).
no sense being a free snow plow and messing up my kit and rims.
Thursday, October 19, 2006 10:10 PM
I used to just remove the front and go back to stock wheels like cannon said. Def worth the time to save 100's of dollars in repairs and repaints
