1996 Pontiac Sunfire 2.2 OHV overheating - Maintenance and Repair Forum
Thursday, October 19, 2006 6:34 PM
Okay, I read just about everything on the forums....check this out, overheats when thermostat is in, doesn't even get in to the normal temp range when it's out. I tested the thermostat in boiling water, it works fine. The fan comes on just fine. The radiator is a normal temp on both sides and no coolant leaks anywhere. The radiator was flushed with a garden hose and it flowed fine. Block was also flushed and the system was Burped.
Re: 1996 Pontiac Sunfire 2.2 OHV overheating
Thursday, October 19, 2006 11:58 PM
Maybe one of the upper and lower rad hoses are colasping, Could have little bit of blackage in youre rad cores, Plugged Heater core, Leaking H/G.
