Hey guys, i never really cared but my horn doesnt work and sometime's when i approach somebodys house and i would like to honk but because i dont have no horn i have to get out and knock on that persons door, the problem with that is those people have guard dogs that will bite the crap outta you. Is there like a fuse or where bouts the horn is located?
Well you can take a looking in youre fuse panel to see if the the fuse is blown, Or could be youre horn assembly wiring harness is unpluged, Or the horn it self is no longer working, I believe youre horn is located, front drivers side under the bumper.
Good Luck.
Rite on, thanks ill check that out.
horn is under the fornt bumper passenger side. and the fuse can be labeled horn or cig(cigarrette lighter).
I may run 18s, but I can do your taxes in 10 seconds flat.
Good news, the fuse in the fuse panel the one "Machzel02" mentioned was burnt so i replaced it and now it works!!!
thanks guys
