might have a pinched PS hose
I may run 18s, but I can do your taxes in 10 seconds flat.
Machzel08 wrote:might have a pinched PS hose
Well thats what you wanna hope for.
Sounds like the pump going bad or rack problems.
Or possibly a control arm stuck or something.
Cant be sure...
But I hope it helps
...They just HATE it when you ...POINT - LAUGH - then DRIVE OFF AND AWAY-!...
is it that its hard to turn left or wont turn left at all.....try jsut putting the key in run but not turning it on, if it moves left then ur rack is bad. if it only prevents you when the car is runing its the pump or something in that region
it dosent sound like a pump problem but im not there to see exactly what it is doing, chances are high that its a rack issue, shouldn't be a hose cause it is flowing enough fluid to help you turn right, its not an easy problem to check on the ground, there are some tricks you can try but without a rack its pretty hard to do that
