Howdy,
When i turn my lights onto low beam the right side works fine fog light and all but the left side everthing is dim. ( headlamp and all). When i turn on the high beam the foglights stay on ( very dim) and the left side is really dim but the right side is perfectly fine. What is my problem? any input is appreciated thanks alot,
Tom A
"Boost tuning"....... have you had your 8 PSI today?
future name of the winter shop!!!
noone
why does all the weird @!#$ happen to my car lol
sounds like my f@&$% headlights. one side is fine and the other is all dim
check the wiring harness under the battery
ToBoGgAn wrote:check the wiring harness under the battery
I have the same problem.
How do you get the connector part there?
I ran Ohm meter from + on battery to Orange cable at light bulb with coming back broken link.
The other left headlight came back with .03 Ohms.
I then ran from Fuse box to right light and still broken link.
Mine is broken somewhere between the fuse and the light. So I figure somewhere in the connector? But unable to figure out how to get the connector apart.
Agreed,
Sounds like your getting too much resistance to the left side lights. Check the wires (exposed or broken), relays (for a humming noise), fuses (if blown), blah, blah. All in all, it could just be a bad ground!
Hope it helps!
...They just HATE it when you ...POINT - LAUGH - then DRIVE OFF AND AWAY-!...
have you replaced your bulbs?
one problem i had is when after i put in some "white" (eurolight) bulbs.. it kept burning out my headlight switch. i opened up my turn signal switch... a lot more stuff was shiny metal than should have been, looked like melted solder.
gmpartsdirect.com has them pretty "cheap"
my problem was my headlights STOPPED working. period. so, its just a hunch.
good luck
www.michaelsportfolio.com
