1995 Z24 wtih Quad 4 motor. After two months seen the car sitting with half the lifters replaced, I put the thing back together. Timing carefully not touched to prevent problems. Car crank but won't start.
What could it be? After a few cranks I check the spark plugs and found them wet (gas). Connection are well put together.
Any suggestions or advised will be appreciated. Thanks in advanced,
CRP
2 months of sitting? check your battery and altenator and see if they are working
Dave Denman wrote:do you have spark?
That will be in the agenda when I get home
Battery was recharged and is good shape. Alternator also checked .
Must check this. Also after cranking so much you should deffently give your battery a charge.
JoeyDaBomb wrote:Dave Denman wrote:do you have spark?
You're correct Joey. I've done it.
......that I have no power coming from the wiring that connect to the coil pack, module....whatever you want to call it. I put new spark plugs (Platinum A/C Delco). Tommorrow I'm going to get a new Battery. The one that i have got low very quick cranking the engine without the plugs in. So I'm not going to think that one twice and not taking any chances.
check your crank sensor and wire leading to it
matt wentz wrote:check your crank sensor and wire leading to it
Thanks Matt But where is that Sucker located?
