New Brake Drums Question - Maintenance and Repair Forum
Monday, September 25, 2006 1:11 PM
Does anyone know what the size is of the rear drums on a 2001 Chevy Cavalier Z24. I am ordering off the NAPA site and they have them for w/ 200mm X 45mm Brakes or w/ 225mm X 45mm Brakes. Im not sure wich ones to get? Any help would be appriciated.
Re: New Brake Drums Question
Monday, September 25, 2006 3:54 PM
it should be stamped on the outer ring of the drum, if i remember correctly
Monday, October 02, 2006 12:25 PM
Yea I took a look and it says 201.9 mm. Im guessing thats the size, but Im not sure wich one to replace it with? Any ideas?
Monday, October 02, 2006 2:36 PM
get the 200mm ones, if you have the spare cash get both as a just is case thing, so you would not have to run back to the auto store when it come time to change them.
Tuesday, October 03, 2006 10:11 AM
The 201.9 is the max diameter they can be re-machined before they are total junk. They were 200 from the factory.
Don
Tuesday, October 03, 2006 10:36 AM
What size shoe should I go with, w/ 7.87" X 1.77" or w/ 8.86" X 1.77". Does it really matter?
Saturday, October 14, 2006 11:14 AM
I am guessing one is bigger than the other, so would the bigger one be better?
Saturday, October 14, 2006 6:52 PM
wow its incredible no one has answer this. anyway, jbodies in 2003 i believe came with a bigger rear drum, which is where the 225/8.86 comes into play. all jbodies below that came with the smaller 200/7.87 ones. get the right ones, because if you wont they just wont fit. if you dont know which you have, look at your drum and you'll see.
Tuesday, July 03, 2007 8:15 PM
Viper98912 wrote:wow its incredible no one has answer this. anyway, jbodies in 2003 i believe came with a bigger rear drum, which is where the 225/8.86 comes into play. all jbodies below that came with the smaller 200/7.87 ones. get the right ones, because if you wont they just wont fit. if you dont know which you have, look at your drum and you'll see.
you sir answered my question
Tuesday, July 03, 2007 11:09 PM
the 7.87 OD drum is the 200mm one.
google.com-"200mm = ? inches" (minus quotes)
Wednesday, July 04, 2007 1:09 AM
Since I just did my rear brakes, I also got 01 cavalier, Youre rear drums and brake shoes are gonna be 200.mm ones, 7/8's are the correct ones. I brought my old ones in matched them, I had a hell of time finding the drums, Brake shoes were easy to find.
Good Luck.
