New Thermostate in overheating!!!! - Maintenance and Repair Forum
Thursday, September 21, 2006 1:25 PM
I put a new thermo stat in and what a bitchh to do that anyways i filled up the coolant went for a spin started over heating really bad add more coolant looks at the right level. Now over heats just as bad and squirts coolant out the tube wtf???? Could their be air int he system if so how do i fix that? Thanks in advance!!!!
darkblade j
Re: New Thermostate in overheating!!!!
Thursday, September 21, 2006 1:56 PM
well I drove it again and the temp gaudge bounced all over hot to cold to hot to cold. poped the hood and the upper raditior hose is rock hard seems to be full of air wtf?
darkblade j
Thursday, September 21, 2006 4:41 PM
If this is for the Sunfire in your profile check out: Coolant Change Read the section about venting the system around figure 11.
In either case, I think your need to bleed the system. This is done by opening the bleeder valve and filling the overflow tank until coolant flows out. I think this can also be done while the engine is running, but don't quote me on that. I don't know where this valve is located if this is for the 05 in your profile. Hopefully someone will chime in to help you out if that is the case.
Good Luck
Thursday, September 21, 2006 5:37 PM
Did you test the thermostat before installing it? These things are not the most reliable product.
"The Blue Bullet"
Thursday, September 21, 2006 6:35 PM
NO i sold the sunfire. Its my ecotec cavy weres the bleed valve on that?
darkblade j
Thursday, September 21, 2006 6:36 PM
Either you have a bad thermostat or it is in backwards. If you want to bleed the system---
open the cap
run the car
the coolant will start to bubble, possibly overflow. this is normal
when it stops, stop car and replace cap
enjoy
Ban low-performance cars, not high-performance ones.
Thursday, September 21, 2006 7:41 PM
Well the 2005 has a different thermostat then the other ecotecs its hudge. Anways it will only fit in one way its in the right way. Is that really how you bleed it take tha cap off and run the car?
darkblade j
Friday, September 22, 2006 4:44 AM
well are you even positive its the thermostat thats bad? could be a water pump or even a head gasket (i doubt its a head gasket cuz the car is still new but it still could be)
Friday, September 22, 2006 7:52 AM
Its one way. If you have a puke line you don't need to worry about it, the car will bleed itself out natually.
Sam
