P0455 Evap Emmisssion Control Sys Leak (Large) ?/ - Maintenance and Repair Forum
Sunday, September 17, 2006 6:09 AM
What is it ?
NightmareSS - 2005 Chevy Cobalt SS/SC STG 2
Re: P0455 Evap Emmisssion Control Sys Leak (Large) ?/
Sunday, September 17, 2006 8:17 AM
well, even if i were to just judge by the name, it means you have a large leak in your evaporative emissisons control system. essentially, this system is made up and is intended to be a completely sealed system consisting of your fuel tank and filler neck, including your gas cap, the evap canister, vacuum lines connecting them, as well as the purge solenoid and canister vent valve. it means, somewhere along the line, in one of those components, there is a problem that is not letting the system hold a vacuum.
Sunday, September 17, 2006 8:18 AM
also, this code is closely related to the p0440 code: evap system malfunction. start with tightening your gas cap.
Sunday, September 17, 2006 9:11 AM
I've given up on that code. Thats like P0001, theres something wrong with your car
Sunday, September 17, 2006 9:14 AM
P noob u mean? I may have just found my sig... (goes to car for picture of actron scanner...)
Sunday, September 17, 2006 3:46 PM
I had that code a while back on a 1997 2.2. In the end it turned out to be a crack in the EVAP vacume supply line at the bend beside the intake manifold/throttle body. As this is part of the multi line manifold made of hard plastic, I was able to cut out the damaged plastic bend and find a short piece of standard vacume hose the right inner diameter to splice in a new bend.
Sunday, September 17, 2006 3:49 PM
exactly,it could be anything that would make the system not hold a vacuum.
