Replacement filter for intake - Maintenance and Repair Forum
Tuesday, September 12, 2006 8:51 PM
Ive noticed that my intake filter is startin to get dirty now. i have the rksport wai, and ive cleaned it with water and dried it a couple times. i wanna get a new one and wanna know wut u guys have done about this. Ive heard of people getting like 3 filters and cycling and cleaning them. so should i buy another one or invest in a k&n filter?
Re: Replacement filter for intake
Tuesday, September 12, 2006 9:31 PM
any help?
Tuesday, September 12, 2006 9:37 PM
K&N's the way to go in my opinon.
Sold 6/30/06.
Tuesday, September 12, 2006 9:55 PM
so basically just get a new k&n filter for it?
Wednesday, September 13, 2006 6:54 AM
just buy a regular filter from ebay. they are the same as k & n and way cheaper. they do the exact same job you can get them for bout 9 bucks maybe on ebay.
Wednesday, September 13, 2006 9:25 AM
Not sure if the ones on eBay for cheap are washable, though.
Rob
Sold 2/2/05
Wednesday, September 13, 2006 11:17 AM
I would stick with K&N better investment.
Wednesday, September 13, 2006 1:40 PM
Could also try the fram air hog. Found them cheaper at wally world then the k&n drop ins...
'96 Cavalier Good ol' Pushrod 2.2
-24X,000 miles on factory build
-Some oil loss between changes, me thinks it be rings.
Wednesday, September 13, 2006 7:04 PM
You can clean/wash the K&N indefinitely. The cleaning kit costs something like... $10 I want to say, and it's good for a number of cleanings. I'd invest in that.
Sold 6/30/06.
Wednesday, September 13, 2006 8:41 PM
wait, if you have the rksport wai, it already has a K&N filter. Just go to a pepboys or advance and pick up a filter cleaning kit
Wednesday, September 13, 2006 9:53 PM
If you do have a K&N on there now, it will say on the end. And you said you've cleaned it with air and water? Then you've probably just been skipping over the re-oiling. I bet once you clean it and spray new oil on there it'll look brand new. Just go somewhere and buy the K&N Recharge Kit... thing.
Sold 6/30/06.
Thursday, September 14, 2006 3:47 PM
okay im not 100% sure it's the rksport, cus it came with the car, but i am 100% sire it looks like this....
so if it is the k&n ill get the recharge kit, but if it's not any filter will fit?
Thursday, September 14, 2006 8:05 PM
That doesn't look like a K&N. If the filter doesnt say K&N somewhere on it then it's probably not. Will any filter fit? Not really, but kind of. Measure the diameter of your intake, or easier just take your old air filter into the store and match up the ends. The end of the filter that connects to the tube needs to match the tube size. You can get the filter off by losening that metal clamp... then just wiggle it off of the intake.
Sold 6/30/06.
Thursday, September 14, 2006 9:23 PM
yea i looked at it and its not, that means i cant use the k&n recharge then right? ill just go to pep boys or autozone and get another filter then. but those things are like 30+
Thursday, September 14, 2006 10:17 PM
I doubt it can be cleaned, but I could be wrong. Yes air filters are faily expensive, but you have to look at it like an investment.
Sold 6/30/06.
Friday, September 15, 2006 12:54 AM
Other cone filters can be washed but it depends on what kind of filter you got. K&N are oil based filters, thus can be washed via the K&N cleaning kit. The ones on ebay (now heres where it gets tricky) can and cant be. If its an oil based one, then you can use the K&N kit for it or the Spectre brand cleaner kit. If its a paper, sponge or cotton fiber, then you simply just blow it clean with compressed air (from the inside out).Oil based filters wont clean as easily as paper/cotton/sponge based filters so if you start blowing a filter and the filter color doesnt start coming back, then use the kit. Another way to test for an oil based filter is to get a white sheet of paper, fit a piece of the paper in between the grooves of the filter and sqeeze with two fingers. You'll notice a slight oil stain/translucentness if oil based.
Poly Fiber Oil based = Cleaning kit
Paper/Cotton Fiber based = Blowing compressed air (from inside-out)
Sponge based = Soak in luke warm water or blow out.
Also a good way of keeping it clean is to rotate between other filter as stated in a previuos post. K&Ns work great as do Air Hogs
Hope it helps.
...They just HATE it when you ...POINT - LAUGH - then DRIVE OFF AND AWAY-!...
Friday, September 15, 2006 7:15 AM
The Fram Air Hog is an oil based, reusable air filter as well...
Friday, September 15, 2006 9:37 AM
i think mine is the sponge kind, but ill probly go with the air hog so that i can use the recharge kits. thnx guys
