I have searched high and low through these forums and even on the web with no luck. What I need is a picture of the harness on the alternator of a 95-99 2.2 OHV engine. The one with only 2 connections in the middle of the harness which is oval shaped with 4 total spots.
What happened is, I was replacing the water pump and I got ahead of myself when putting the alternator back on. As usual, things never go as plan or I want them to. The 2 wires were ripped right out of the harness and I have no idea in which sequence they go.
If someone could either post a link to a post with the pictures I'm looking for or if someone could post pics of what I'm looking for I would greatly appreciate it.
________________________________________________________________________
----All Your Cars Are Belong To Me!-----
Hi Mike
I realize it's a late reply but, how does this match up to what you have.
If your system does not have the same pin ident letters post back and I will give some alternates.
http://www.autoshop101.com/forms/h8.pdf
Hope it helps, anyway
Alont
thanks, i fixed it already. i just needed a pic of the harness that plugged into the alternator in color cause the wires were ripped out of it, nearly clean rips. my alternater has 2 wires going into it, grey and red, thats the reason i need a color pic of it.
since i was driving by Bessler's You Pull and Save on my way back from NKU i decided to stop there and found a newer 2200 OHV Sunfire with almost the exact same harness, it worked.
now all i need to do is replace the timing chain tensioner...
Off topic, but alont, you are always so polite with your posts. Its almost unseen this day and age.
Well. Thanks
Maybe 'cos I was born in another age
Appreciate the comment
Alont
