high idle - Maintenance and Repair Forum
high idle
Wednesday, September 06, 2006 9:41 AM
i kinda searched but not really hard but heres my prob an i hope you guys can help. i have a 99 cav z24 5 speed an recently its been actin wierd i noticed when i push the clutch in the rpms jumps 500 annoying but not the big prob sometime while driving the rpms jump up an stay at 3000 not good . since i dont get a service engine light autozone cant help. just looking for an idea as to whats wrong here cuse to me this is really odd. thanks
Re: high idle
Wednesday, September 06, 2006 1:29 PM
join the club. triyng to figure my high idle out for months....good luck
Re: high idle
Friday, September 08, 2006 7:20 AM
well i found out that if it get stuck idling high while driving if i floor it real quick it goes back to normal but i have to be in gear.does anyone have even the slightest idea what could be goin on here? i really dont want to take it somewhere an find out it was something that i could easily fix
Re: high idle
Friday, September 08, 2006 7:40 AM
Sticking IAC valve?
Re: high idle
Friday, September 08, 2006 5:52 PM
From your description, it's either a sticky/dirty idle air control valve or a sticking throttle cable. Try cleaning the iac. If that doesn't work, disconnect the throttle cable, point it straight up and spray as much wd-40 down it as you can.
John Wilken
2002 Cavalier
2.2 Vin code 4
Auto
Re: high idle
Sunday, September 10, 2006 11:34 AM
well i fixed it not really sure what the exact prob was i think it was the iac so i cleaned that ,cleaned the throttle body.lubed the accelerator cable ,ran some seafome throught it (i love that stuff its great) then changed the oil. now shes runnin like almost new. thanks for everyones help
Re: high idle
Sunday, September 10, 2006 3:23 PM
You know...a properly running, well mainained engine never needs Seafoam.
'96 Cavalier Good ol' Pushrod 2.2
-24X,000 miles on factory build
-Some oil loss between changes, me thinks it be rings.
Re: high idle
Sunday, September 10, 2006 3:45 PM
David Jones wrote:You know...a properly running, well mainained engine never needs Seafoam.
Umm, doesn't Seafoam fall under the catagory of "maintanence"?
John Wilken
2002 Cavalier
2.2 Vin code 4
Auto
Re: high idle
Monday, September 11, 2006 6:10 PM
Need to know where the IAC is located...
coming home tonight the car was idling crazy, around 2400 rms she was accelerating the entire drive home...
got her home when i put the car in the driveway she kind of went back to normal...
i will clean the iac as soon as i find it.., lube the cable etc..and go from there..
please advise where the IAC is asap...
Kristen
Re: high idle
Tuesday, September 12, 2006 12:14 PM
my older cavy with the old 2.2 did the same thing. on your throttle body you should see something very similar to this
it is on/ around the throttle body. You can go to any junk yard and grab one for pretty cheap. if you want brand new your looking at around 100+ bucks at advanced auto parts. One thing you can do I did for one of my cavys is take it out and clean it with brake cleaner then dry very well VERY well. take a clean rag and wipe the inside of the hole it came out of. place it back in and try again. best idea is just to replace it.
