alternater not charging battery cant figure out!! - Maintenance and Repair Forum
Saturday, September 09, 2006 8:29 PM
ok guys i need some help big time i have done everything i no to do and im back where i started.... here we go i was driving down the road my lights get dim the car dies battery lights on. have it towed to my autobody shop and replaced the altenator and the battery at the same time. at my local oreillys they said that the voltage regulator was most likly my problem and it was in the computer so we replaced the computer and the car is all put back together with new computer battery altenator and i put a new starter on cuz it was going back and im back to square one of the altenator not charging the battery!!!! im so lost and confused and i need to no if anyone else noes what i should do or had this problem please let me no!!! the car is a 1997 2.2 liter ohv auto.
thanks alot!!!
Re: alternater not charging battery cant figure ou
Saturday, September 09, 2006 9:54 PM
Have you made sure you don't have any broken wires and the alternator is grounding correctly? You should have zero resisntance between the body and alternator casing.
'96 Cavalier Good ol' Pushrod 2.2
-24X,000 miles on factory build
-Some oil loss between changes, me thinks it be rings.
Saturday, September 09, 2006 11:28 PM
well i check the plug to make sure no brokin wires and tomarrow im going to try to play follow the wire " everyones favorite game" haha and figure out where they go but all i no by looking at it is they go behind the motor somwhere
Sunday, September 10, 2006 5:59 AM
You need to verify the connection between the battery positive terminal and the generator output using a volt-ohmmeter. You could have an open fusible link. Just a point of information...the PCM is not the regulator. It does send a turn-on signal to the generator when the engine is running, but the regulator itself is contained within the generator.
Sunday, September 10, 2006 6:36 PM
Lees04Cav wrote:You need to verify the connection between the battery positive terminal and the generator output using a volt-ohmmeter. You could have an open fusible link. Just a point of information...the PCM is not the regulator. It does send a turn-on signal to the generator when the engine is running, but the regulator itself is contained within the generator.
^^ he is right on. The easiest way to check for the broken wire is to do what is called a voltage drop test. To do it get a volt meter (digital perfered) set it to the correct scale (either 12 or 20 volt depending on the volt meter) put one lead of the volt meter on the stud of the altenator where the battery cable attaches and the other lead on the POSITIVE battery terminal. Be very sure you have your meter set to volts other wise your gonna have some sparks and prolly blow a fuse in your meter. Your reading should be less than 1 volt. If you have any thing higher than that your connection between your altenator is broken (either the wire is cut/corroided, or the fuseable link has blown)
That should tell you what is going on, if you need anymore help let me know.
200 wheelhorse or bust
Monday, September 11, 2006 4:48 PM
hey guys i realy appriate the help i did exactly what you said i set down and studied my situation and figured out a ground wire i couldnt see got stiped out and was rubbing a piece of metal i got it figured out now
thanks alot!!!
Monday, September 11, 2006 5:08 PM
Cool,
Ryan1
