hey, coming home today and clicked on my turn signal and nothing happened.. everything works inside except for the signal lights, they don't work outside either. checked the fuse. what could cause this?
Okay you checked the fuse, you didnt say it was blown so I assume it isnt?
Anyways bad switch, bad wiring to the fuse, bad wiring from the fuse to the switch also can cause this, and open circuit anywhere up to the splice will cause this.
no the fuse is not blown.. it just happened just like that. ya i guess i will have to check the stuff out then. anyways thanks alot guys
How about the bulbs? If one was burnt out, it would make your signals blink hyper fast, but I'm not sure what it does if both are burnt out lol.
Rob
Sold 2/2/05
