Dual exhaust and gas lines - Maintenance and Repair Forum
Monday, September 04, 2006 9:50 AM
Is there any problems runnin the 2nd exhaust pipe right below the fuel filler hose? would i need to put a heat sheild there?
Re: Dual exhaust and gas lines
Monday, September 04, 2006 10:12 AM
I have a gt with the 2.4 and duals. There isn't a heat shield on mine, but the duals split just before the axle and the pipe for the passenger side turns behind the axle. It's no where near the fill tube. If you think it's too close, trust your gut and route the pipe another way.
I'm half-way through putting on a pacesetter header and running 2 1/2 exhaust. I bought an equalizer tube from summit, link, to T my one pipe into 2. If the stock rear valance didn't already have the cutout, I'd be running the single pipe.
If you're interested in doing this, the kit came with 2 of those T's and I only need one. 10 bux should cover shipping to pa, let me know.
John Wilken
2002 Cavalier
2.2 Vin code 4
Auto
Not required but insulating heat wrap isn't a very expensive precaution.
'96 Cavalier Good ol' Pushrod 2.2
-24X,000 miles on factory build
-Some oil loss between changes, me thinks it be rings.
Monday, September 04, 2006 7:13 PM
wouldn't that H pipe half make the exhaust run out of the straight pipe more then the tube thats just stuck at a 90* angle into the pipe. What im sayin is that the exhaust will just go straight past the other pipe cuz theres really nothing in there to direct the flow into the other pipe.
