Drl Light Flashing on the dash, HELP! - Maintenance and Repair Forum
Friday, September 01, 2006 2:25 PM
The Green light on the dash is flashing, (like every second). My Low beams and drl light is not working, but my high beams works fine. I checked the fuse and light and all of them is fine, i dont know whats wrong with it. Help Please. Thanks
Re: Drl Light Flashing on the dash, HELP!
Friday, September 01, 2006 2:26 PM
btw, i have a 97 cavalier. thanks
Friday, September 01, 2006 3:07 PM
The one time I had this problem, it turned out that my aftermarket headlight bulbs FRIED one of the harnesses. Bought a new harness at Advanced, wired it in with a new set of bulbs, problem solved.
Check your low-beam harnesses
Friday, September 01, 2006 4:07 PM
What do u mean?! i need to change the whole set of wire?! or just the wire for the low beam lights?!
Friday, September 01, 2006 4:12 PM
Easy boy, easy...go out and CHECK the harness before you get all worried.
If that WERE the problem, you'd have to cut the harness off (3 wires) and connect the new one. It's not rocket science by any means.
Saturday, September 02, 2006 4:28 PM
CHeck to make sure you dont have a high beam out.
