Hey guys I need some help if someone can find me torque specs for the
Pressure plate to flywheel
and flywheel to crank bolts I would appreciate it, I believe thats all I need as of right now
Edited 1 time(s). Last edited Monday, August 28, 2006 8:01 AM
LE61T PTE6262 Powered
According to the 04 FSM:
flywheel-to-crank bolts
first pass - 39 lb-ft
final pass - 25 degrees
Pressure plate-to-flywheel
18 lb-ft tightened in sequence (like you would a wheel by crisscrossing)
thanks and what about the timing chain housing bolts?
Front cover bolts - 18 lb-ft
