Engine Temp ? - Maintenance and Repair Forum
Engine Temp ?
Wednesday, August 23, 2006 7:44 PM
Hello, im new here and i have a quesiton? My car is a 95 Chevy Cavalier with the 2.2 166K mile's, 5 speed. My temp gauge is rite in the middle but when i accelerate up a hill it move's a little bit to the "Hot" then goes back to the middle. I notice that my engine cooling fan doesn't come on when its idling. There's no engine defects its just wants to overheat a little when im going up hill's. Also if i decided to flush my radiator where would be the drain plug for it or do i have to loosen the bottom radiator hose to change the fluid?
Re: Engine Temp ?
Thursday, August 24, 2006 9:50 AM
The fan doesn't come on until it points about half way between normal and "hot". You're fine if it never hits the red zone.
Re: Engine Temp ?
Thursday, August 24, 2006 11:54 AM
Yep, you've got a normal cooling system. Drain plug located bottom, driver side. Unscrews a few turns to open, then pull to remove (if necessary). Best to have it backflushed every 100K miles. Don't mix coolant types.
Re: Engine Temp ?
Thursday, August 24, 2006 4:43 PM
When the temp gauge is in the middle the fan doesn't come on and when i let it idle for quite some time, it will overheat just idling. For some reason it doesn't wanna work, so far i changed the temp sensor, cooling fan relay, and now im changing out the cooling fan in a bid hoping that might help. I have question, removing the fan i notice thats there one bolt and the fan slides out but i can't seem to get the top section off. I slide it back and fourth but it seems to not come off. How do i remove it ??
Re: Engine Temp ?
Thursday, August 24, 2006 6:36 PM
Update. I changed out the fan but it still wont click on when the engine is idling, im pretty much stumped cause i changed the sensor and the fan. I did a power test with the wire that plugs into the fan, one wire showed power and the other wire didnt but i was told that the wire that didnt show power is the ground. With the old models does the fan come one when the vehicle is in motion? or ? Also could it be the thermostat that's making my car overheat?
Thanks for any response's
Re: Engine Temp ?
Thursday, August 24, 2006 8:43 PM
What's strange is my fan is on ALL the time.
Re: Engine Temp ?
Thursday, August 24, 2006 9:04 PM
Fan should not be on all the time unless you have the AC on too.
Lonnie: sounds like it might be a dead fan, try wiring it directly to the battery to see if it works.
Re: Engine Temp ?
Friday, August 25, 2006 4:07 AM
For mid-late 90s manuals with 2.2s, dead middle of the temp gauge is 195, normal operating point. Fan will be on either when the temp gets about 4/5 the way up the gauge, and/or whenever the A/C compressor is on (this includes defrost mode).
Re: Engine Temp ?
Friday, August 25, 2006 4:37 PM
^That is correct.
Re: Engine Temp ?
Saturday, August 26, 2006 8:34 AM
Thanks guys. The starting working when the gauge went up, it came on with the it reach between the middle and hot and went back to normal.
Re: Engine Temp ?
Saturday, August 26, 2006 3:14 PM
Don't worry about it my car does the same thing up hills@85 when the a/c is on.
'96 Cavalier Good ol' Pushrod 2.2
-24X,000 miles on factory build
-Some oil loss between changes, me thinks it be rings.
