Interior lights flickering...? Short maybe? - Maintenance and Repair Forum
Monday, August 21, 2006 6:02 PM
Hey guys....here's the sit.
Usually I drive with my interior lights dimmed to the lowest setting. Recently my odometer started to dim out and after that I noticed a brightening/dimming fluctuation on my interior lights ( the dash lighting and HVAC controls). My radio is staying the same, so could this be a short in my headlighting system somewhere? It only occurs during the dark hours when I have to have my lights turned on..... I had recently wired my guages up, but have triple checked my connections, including my connection to the headlight? Any ideas? Thanks a ton!
ShiftyCav wrote:thats probably the dumbest thing i have ever heard. you should take that serpentine belt and wrap it around your neck.
Re: Interior lights flickering...? Short maybe?
Monday, August 21, 2006 6:44 PM
Loose connection, most likely your ground.
Tuesday, August 22, 2006 10:29 PM
Thanks, I'll go check that out.
Wednesday, August 23, 2006 3:08 AM
ya def ground or rare chance ur actual dimmer switch or headlight switch is bad. but check ground
Wednesday, August 23, 2006 7:02 AM
Actually funny thing you mentioned the dimmer switch ....becuase the the flickering only occurs when my dash lights are set to the lowest. But as soon as I "increase" the brightness, the flickering goes away, like back to normal. But also I've had my headlight switch replaced before, and it wouldn't suprise me at all if its going now too. so I'm gonna check the ground, then the dimmer, and finally if nothing else the headlight switch. Thanks a gain everyone.
Thursday, August 24, 2006 11:22 AM
Sounds like a ground, or it may be a little bit of dirt/crap in the swtich. Most of those switches use a variable resistor, lots of "winds" of tiny wire around a shaft. Like the old TV tuners & radio tuners did when they were analog. If you check the grounds and it's still doing it, you might pop the swtich out and spray the inside with some electrical cleaner spray. Ya know, it's a dirty world out there.
Don
