Rear Drums - Maintenance and Repair Forum
Rear Drums
Sunday, August 20, 2006 1:20 PM
Hey just wondering about the rear drums. I changed mine no problem... doing a friends and cant ge the drums off... rusted on solid. Tried a few things but nothing working. Any ideas??
Thanks
Re: Rear Drums
Sunday, August 20, 2006 1:27 PM
Slide hammer should do the trick. Also try using brake cleaner to loosen up the rust before doing that.
Re: Rear Drums
Sunday, August 20, 2006 3:48 PM
If its rusted at the hub, squirt liberally with Liquid Wrench, Nut Buster, PB Blaster or whatever rust solvent you prefer. Then wait a while and hit it again. Try tapping on the drum with a rubber mallet to break it loose.
Many times with drum brakes, the problem is that a groove has been worn in the drum by the brake lining. You can't get the drum off because the drum is catching on the shoes. If this is your problem, try backing off on the brake adjuster which will pull the shoes inward and allow the drum to come off.
Re: Rear Drums
Sunday, August 20, 2006 7:59 PM
not discrediting your intelligence.. (i JUST did my rears) make sure the e-brake is off and take the cap off of the brake fluid res. under the hood.
www.michaelsportfolio.com
Re: Rear Drums
Sunday, August 20, 2006 10:33 PM
Well Ive doen a few too many brake jobs, Easy way I figured is to get a foot long piece of 2x4 wood, Just place the 2x4 wood on each side of the drum as a barrier, While striking the drum with a hammer a few times with allow each drum to come off with no problems.
Re: Rear Drums
Monday, August 21, 2006 9:38 AM
Thanks everyone. With a bit of elbow grease i got it off.... had to spray it down and let set over night thought. But its off now. Good thing too drums were getting down there.
