Shift grind noise? - Maintenance and Repair Forum
Shift grind noise?
Monday, August 14, 2006 12:45 PM
Hey guys, when Im shifting it makes some noise sometimes. when I'm shifting from 1std to 2nd, it makes a noise when coming out of 2nd to 3rd. Also does this when I go from 3rd to 4th. but nothing from 4th to 5th. I'm not having problem shifting or not going into gears. I'm just wonder whats causing this noise? Maybe I can lube something to help it? I did get my clutch replaced about 3000miles ago.
Re: Shift grind noise?
Monday, August 14, 2006 4:43 PM
have you changed the fluid in your tranny? I had a tranny with noise from 1st to 2nd in a 95-99 5spd put in GM syncromesh, worked well.
Monday, August 14, 2006 8:15 PM
um.. Would the 60k tune up change that? I thought it would.. I would have to look on my papers to see if they did. It wouldnt be where the shifter under the shift boot? Does that need to be lubed or anything?
