gasket removal - Maintenance and Repair Forum
gasket removal
Sunday, August 06, 2006 1:51 AM
Whats the best way to remove old gasket material? would a wire brush on a dremal hurt the block?? im trin to remove the old gasket off of the water pump area and it aint goin to well. Any tips?
Re: gasket removal
Sunday, August 06, 2006 2:02 AM
I would say get a paint scraper and go to town.
Re: gasket removal
Sunday, August 06, 2006 2:40 AM
its to tight to get anything but a razor blade in there and even then i cant get all the old gasket off, its like "glued" to the block.
Re: gasket removal
Sunday, August 06, 2006 5:00 AM
Scotch-brite green scouring pads. You'll find them in the cleaning supplies section of your grocery store. They are durable, and won't gouge or scratch aluminum, let alone the iron of the engine block.
Re: gasket removal
Sunday, August 06, 2006 6:57 AM
gasket scraper.
Gilles
2.3 Ho
Re: gasket removal
Sunday, August 06, 2006 11:17 AM
Scotch-brite pad red/green and paint thinners if theres a big chunk one can use a screw driver just becareful use take off the top part don't dig into the metal
http://img86.imageshack.us/img86/4235/jim25ek.jpg
Re: gasket removal
Sunday, August 06, 2006 3:52 PM
Ryan, if you have to resort to it, paint and varnish
remover is somewhat of a last resort...
(It's strong stuff)
Anyway, you can keep it off your hands by using
a cotton tipped swab stick and the cotton ball dipped...
Let us know what method you used...
Re: gasket removal
Sunday, August 06, 2006 3:54 PM
i just ended up using a scoth-brit pad and a razor blade (cuttin myself 3 times) and got it down that it was fairly gone.
