clutch problems - Maintenance and Repair Forum
clutch problems
Thursday, July 13, 2006 9:38 PM
ok, a little while ago i posted a problem in here, the problem was that i couldn't shift my car into any gears with clutch pushed in. ok i just replaced master slave cylinder and cltch fluid line with resorvoir. all in all 1000 bucks later. still have the same problem, arrrrrghhhhh. i am right pissed. i still can't shift car unless i pump up the clutch a few times and then press it right to the floor as far as possible. i f i cut a hole in the floor it probably would work. i'm out of ideas i give the @!#$ up. hell if it isn't running i can fly through the gears like no ones buisness. until ya start it. PLEASE SOMEONE WHAT CAN I DO. is there any adjustment.
Re: clutch problems
Friday, July 14, 2006 9:17 AM
You might want to try bleeding the lines of trapped air, if not done already. Also, blockage in a line somewhere? As for adjustment, the system is self-adjusting (hence the fluid reservoir).
Re: clutch problems
Friday, July 14, 2006 6:27 PM
i figured it was self adjusting, just wanted to find out if there was something i was missing. gm is still looking at the problem.
thanks
Re: clutch problems
Friday, July 14, 2006 10:18 PM
yes yes, bleed the cluch, clutches are a BITCH to bleed. can sumtimes take a week to get it fully bled.
Re: clutch problems
Sunday, July 16, 2006 7:24 AM
you said you changed the master slave cylinder, did you mean you changed the ,master cylinder AND the slave cylinder? your slave cylinder may be between your motor and transmission (it is on mine) and thats about the problems I was having. It's a fun job to to, i would check that but if you already changed it.... i have no idea...
Re: clutch problems
Tuesday, July 18, 2006 9:42 PM
ya i replaced it. gm doesn't have clue. they tol me to replace the clutch. thought maybe center forks are bent not doing it's job.
Re: clutch problems
Saturday, July 22, 2006 3:10 AM
I had a simiar problem. I somehow as out of fluid for my clutch. Bought some DOT3 fuild and the problem was fixed. Hope it helps..
