i d k i watched my car pull timing when i step on the gas....im not sure why it seems like trac control is comming on but it wont go....and it usally happens when the ac is on but soemtimes when it is off as well. Also i can feel pressure come out of where you put the oil cap on and was wondering if maybe its my pcv valve thast needs replacing any help would be great...
Thanx Charles
Dunno about the symptoms, our cars dont have PCV valves, they have air oil separators. As about the pressure where the the oil cap is at is normal, the timing components are below it, the chain is spinning.
well....hmmm....what is this pcv/ air oil seporator....is it behind the intake because i ahve oil in my intake box....and i dont think it should be there hahahaa.....but yea the timing its wierd....and sux... i cant launch my car any more because the timing drops like down to -4 deg...... and then it will slowly come ack up to 27 i think it is at wot.....and then like 32-34 when i let off the gas.... id k????
Thanx Charles
No kidding it is going to retarted timing when you step on it. That is a good thing,
It does this to prevent detonation.
but it shouldnt retard it to over -4 deg....its stutters and doesnt move...i know its gonna pull timing im jsut sayin its pulling so much the car doesnt even want to move....
Thanx Charles
