why does my new clutch feel so soft - Maintenance and Repair Forum
Friday, July 07, 2006 4:49 PM
hery guys I just got a new clutch put on my eco after 200 000km and it feels so soft compared to the last. I replaced it with a OEM clutch but the pedal feel is way different. So here is my question......can i get the old pedal feel back< do I need to break it in to get that? Any help would be appreciated. On a side note I also had the slave cylinder replaced
Re: why does my new clutch feel so soft
Friday, July 07, 2006 7:59 PM
Well since it is a hydralic clutch, it will have the same effect if you have air in your brake lines, a spongy feel.
So try bleeding the clutch.
Saturday, July 08, 2006 8:22 AM
Over time, mileage, and heavy use... the clutch pedal will gradually stiffen up. You probably didn't even notice because the change would have been so gradual. When the new parts went on, they will be a lot easier to move giving you a lighter clutch pedal feel. There's nothing wrong with that, as long as the clutch is functioning correctly. You'll get used to the new pedal feel.
Sometimes it's easier to do things the hard way.
1997 Pontiac Sunfire SE 2-door
