dies on starup, then runs fine...!!!!!! - Maintenance and Repair Forum
Monday, July 03, 2006 6:39 PM
ok so everytime i start the car, after like 5-10sec, it idles very roughly and then dies. I need to floor it and keep it onver 5k rpm for it to not dies. then after i kept rpm high for like 20-30sec, the car runs fine and doesn't do that until next startup.
anyone have an idea of whats going on?
thanx.
Re: dies on starup, then runs fine...!!!!!!
Monday, July 03, 2006 7:41 PM
fuel pump?
Tuesday, July 04, 2006 3:48 AM
if the fuel pump was bad, it wouldn't drive fine after i floored it, no?
Tuesday, July 04, 2006 5:17 AM
When was the fuel FILTER last changed?
Alont
Tuesday, July 04, 2006 6:58 AM
Idle Air Control valve is more than likely sticking closed. It is a common problem and will effect it most at cold start, start ups.
Tuesday, July 04, 2006 10:20 AM
When you floor it, does it blow a bunch of black smoke as in it is running rich?
Tuesday, July 04, 2006 12:51 PM
i dunno when was the fuel filter changed, i just bought the car last weekend.
i'll try to put the iac from my cav on this one and see....
I'll also check for smoke and will let you guys know.
thanx
Tuesday, July 04, 2006 3:10 PM
swapped the iac, and no changes.... so its not that!
anyone have an idea of what this could be?
thanx
Wednesday, July 05, 2006 4:51 AM
Wednesday, July 05, 2006 2:47 PM
ok, but why does it act fine and drive very well, even on idle at a light after i florred it for a couple secs....?
all i need to do for it to be fine and drive like normal, is floor it and keep rpm at 5k at start up for about 10-20sec!!!
Wednesday, July 05, 2006 4:53 PM
Cold Start Stumble. There was a TSB for it, but most of the people that had the work done never really saw any benefit.
It's a standard feature on 2.4L with a manual transmission from 96-99. Learn to enjoy, there, to my knowledge, has never been a viable fix developed.
Wednesday, July 05, 2006 6:12 PM
thats is not normal... i have a 97z and it never done that, my friend got a z too, never hapened to him also!!! there is something wrong, that is 100% sure....
also, when i start it up and floor it, white smoke is coming out of the pipe!!!
any help would be appreciate, thanx
Wednesday, July 05, 2006 7:09 PM
Check your FPR. You described almost exactly what my '99 was doing when the FPR went out. That is why I asked you if it was running rich and blowing black smoke. Once the car was started, revved up to clear it out, it ran perfectly. It was just a bitch to get started and wouldn't run smooth until revved up a bit.
And is it white smoke or is it gray/black smoke? White smoke is bad news...that usually means water is getting into the combustion chamber. If it is white, then check your coolant and oil levels and make sure they aren't looking funny.
Edited 1 time(s). Last edited Wednesday, July 05, 2006 7:10 PM
Wednesday, July 05, 2006 7:17 PM
well, it had an adjustable one, i tought it was that so i put the stock fuel rail with stock fpr. but i dunno if i can trust that regulator!!!!
for the smoke, i'm not sure. if i would burn coolant, it would burn all the time, not only on startup right?
well.... i think its time to install the new afpr on the cav, and put the cav's regulator on the sunfire and see...
thanx
Friday, July 07, 2006 6:10 PM
ok, i just plugged my wideband from the cav on the fire and the problem is its running too rich! i see afr of 9-10:1 even after it warmed up. the oxygen sensor was disconnected so i can put the wideband in. black smoke was coming out of the pipe and i checked the plug and they are all black! even the wideband sensor after like 15-20min on the car was all black!!!
i'm going to install the new afpr on my cav and be putting the can fpr on the fire and we'll see...
also with the O2 disconnected, the car didn't die. i know on start up, the car is suppose to run in open loop so the O2 sensor should make a difference on startup, so would a bad ECT be the problem?
any advice would be welcome.
thanx
Saturday, July 08, 2006 10:06 AM
tcc silonoid?
Saturday, July 08, 2006 4:01 PM
x2
Saturday, July 08, 2006 8:54 PM
whats tcc??
i'll check the fpr next week as now i dont have any times and will let you know.
thanx
Sunday, July 09, 2006 11:55 AM
Ignore the TCC comment. It has absolutely nothing to do with what you have described. TCC is the part that fails on the older autos that cause bad shifting and stalling when you come to a stop because the torque convertor doesn't disengage. It has nothing to do with the engine running rich.
