Okay, so about a week ago my car (1998 pontiac sunfire 2.4 dohc automatic) developed a knock above 3000 rpms. I drove it home immediately and figured it was a rod bearing spun. Dropped the oil pan and sure enough the #3 rod bearing has spun.. I replaced all the bearings with new clevite bearings. After driving for about 100 miles it has developed a knock again at about 3000 still... My question is, would it be easier to have the crank turned and recondition the rods... or to just buy a new motor? what kind of motor might i swap in for more power? i've read things about the lgo in the 442 but im unsure if its a bolt in swap.. lastly where is the easiest place to find a used motor for this car??
Thanks!!
craig
I'd say just go to like Advance Auto and buy a crank kit. It will have a remanufactured crank and bearings already together in a box. As long as you didn't spin the rod bearings on top of one another your rods should be fine, just drop the pan and drop the old crank out and slam the new one in it. Oh if you can get hold of a dial caliper it would be a good idea to check the rods big end to make sure its still round and within spec.
Good luck and let me know if you need anything else.
to drop the old crank out, i would need to take the tranny off, and the timing chain housing off too right?
sounds about right, the crank's attached to stuff on both ends.
If replacing the crank i would suggest taking the motor completely out.
man.... the engine just got rebuilted.....
but the knoking noise is not that loud, when warm and in the car even with the glass rolled down, i cant ear it, even if i rev it. I think its only my pistons then, since they are forged and expend more with heat.
thanx
if theres any chance its spun DO NOT DRIVE IT!!!!!!! you will ruin a lot of stuff and waste a lot of money...
