My bro's been practising with my stick cavie yesterday, since it's his 1st time driving a stick he stalled it almost all the time. This morning when I started the car I noticed something, the engine is cranking but wont start, the RPM goes to the redline & stays there when I turn off the engine.
What could be the problem with my car? I change battery, alternator, belt tensioner, a/c comp. (all brand new but a reman.a/c comp.)
All help and knowledge is appreciated. And thank u in advance guys.
U need to update the profile on ur cars info like yr model etc.It could be a number of things,coil packs,the crank shaft position sensor.Do a code check and see if there are any hard codes set in the ecm.I doubt the any of the things u replaced would cause the issue at hand.If the car turns over but does not start it would lead me to believe the two things I mentioned may be possibly a problem.OK
Guys help me out pls.
One more thing i notice in addition to the RPM goes to the redline & stays there when I turn off the engine, the fan kicks in as well, also a screeching sound around the steering area.
Thank you all.
