Out of ideas - Maintenance and Repair Forum
Out of ideas
Thursday, May 18, 2006 4:55 PM
hey everybody,
i'm having a serious problem with my 96 Z24, its missing really bad and i don't know what to do, i've replaced the coilpack housing, the coilpacks, the ignition module and the TPS, and it still misses. has anyone ever had this problem before? any help would be greatly appreciated.
1996 Cavalier Z24-1976 302 powered 280Z
What the heck is a "Datsun" ?
Re: Out of ideas
Thursday, May 18, 2006 4:58 PM
have you checking into fuel injectors? what the milage
friends dont let friends roll stock
Re: Out of ideas
Thursday, May 18, 2006 5:58 PM
Can you describe missing?? It won´t start?
Re: Out of ideas
Thursday, May 18, 2006 7:47 PM
For it to fire you need air, fuel, compression, and spark. Also is this at idle, normal running, dawging it, or all of the above.
Re: Out of ideas
Friday, May 19, 2006 2:30 AM
I would say a compression test would be a good start
Re: Out of ideas
Friday, May 19, 2006 10:13 AM
/\ /\ Thinking the same thing, but didn't want to jump to conclusions about a headgasket or rings. The timing chains arent infallable either. If the tensioner aint tensioning or jumped a tooth........
Re: Out of ideas
Saturday, May 20, 2006 3:30 AM
don't jump to conclusion. Change the boots and the plugs first.
Gilles
2.3 Ho
Re: Out of ideas
Monday, May 22, 2006 9:29 AM
thanks guys also i ohmed out the injectors they're fine and fuel press. at idle is 42 psi, i think ill replace the plugs and "wires" and do a compression test.
Re: Out of ideas
Monday, May 22, 2006 9:46 AM
I had same problem however your first choice of action was my last due to cost of parts. I compression tested mine, did a fuel pressure test, changed plugs and boots and priced up some computers. mine was either icm or coilpack... i changed them both together and it worked fine.
Re: Out of ideas
Monday, May 22, 2006 9:54 AM
i talked to my fiance he says to check the computer plug in the right front wheel well. I guess they are known to corrode there.
Re: Out of ideas
Monday, May 22, 2006 2:22 PM
i have come to relized the coil housings on the 2.4 are crap and half the people i spoke with on rough idles and missfires turned out to be coil housings
