replacing a 2.4 twincam - Maintenance and Repair Forum
Sunday, May 21, 2006 6:25 PM
Hello, I have a 1998 z24 convertible with a 2.4 twin cam engine that i blew about a month ago. This week is $65 engines at harry's u pull it in hazelton pa and i was thinking about taking a look around for a replacement. Now i know that grand ams, sunfires, and alero's also had this engine in certain years, could anyone post me a list of years and vehicles which have compatible engines that i can drop into my car. I want to do a 3800sc swap, but wouldnt have the time to get everything done, as my goal is to have my car ready for the premier for ff3 at my local movie theater, we have rycers lined up outside, and i would like a running car again... any help is apreciated...
~twizt3d
Re: replacing a 2.4 twincam
Monday, May 22, 2006 2:55 AM
96-99 2.4. for the 99, check the injectors lenght. If it's a long injectors, you can't use it.
Gilles
2.3 Ho
Monday, May 22, 2006 5:16 AM
what about like grand ams, or sunfires, same years apply? and i know newer alero's have the engine, can I use any of those or no?
Monday, May 22, 2006 8:41 AM
a 2.4 is a 2.4. They are the same wether they come from a GA or a cavy.
Stay in those years and you'll be fine.
Gilles
2.3 Ho
Monday, May 22, 2006 10:53 AM
could you tell me the hp ratings of the 2.4 compared to the 2.3ho? and if it would be worth it to hunt for a high output engine instead... im talking entire engine, not just the tb and intake manifold... basically what are anyones suggestions on what i should do to make the most power, without having to get my pcm reprogrammed, i was looking into the v6 swaps until i found out that gauges dont work, i dont want to redo my entire interior... i guess, just rip a 2.4 and mod the air intake to the h.o? or are internals different.... im sorry but i come from a rycer background, my modifications involve a body kit, lambo doors, led underbody kit, interior and audio, aside from a dtm muffler with axel back piping, and an intake, i have nothing, but im looking to change that lol, i was going to do the 3800sc swap because i actually found a possible donar car, but the computer work is too much for me, what suggestions does anyone have?
also what about alero's they are more abundent, and were made from 00-04 i believe with the twincam, my neighbor has an 01 with my engine....
Monday, May 22, 2006 11:02 AM
stick with the 2.4L, you will be better off.
Monday, May 22, 2006 11:27 AM
so your saying stick with just the 2.4, and dont swap anything...
Monday, May 22, 2006 11:41 AM
Its an easier swap to put the 2.4 back in, 3800 S/C is tons of work, and lots of $ to do. Your car now is setup for the 2.4, and a 2.3L swap would be tough for wiring purposes as well. As for 00-02 2.4L's a lot more has to be done to swap it in. Better off looking for a 96-98 2.4L as well, 99's were the rare one's of the bunch, but a blessing when using some newer parts (like the GM S/C for the LD9). Best sticking with what you have.
Monday, May 22, 2006 11:50 AM
what kind of power gains would i be looking at if i used urweak's guide and just modded to a h.o. intake... also the w42 engine that made 190hp, what was that in, and what was special about it that made is get an extra 40 ponies...
Monday, May 22, 2006 1:30 PM
The W41 made 30 hp more than a Lo and 40hp more than a 95 2.3.
1- Better head
2- Bigger cams
3- Better intake manifold
4- Better exhaust manifold
5- Better timming and fuel map
6- Higher compression
7- Lighter parts
8- No balance shaft (compare to a 95)
It was ONLY in the 92-93 Achieva Scx and in some 91 442
Gilles
2.3 Ho
Monday, May 22, 2006 2:14 PM
remember if you get a 99 2.4 out of a cavi it wont have a egr set up your 98 does
friends dont let friends roll stock
Monday, May 22, 2006 5:05 PM
yes thankyou, forgot about the egr valve... anyway, it seems like the w41 is impossible to find and not worth the trouble of the swap for me as i just read into it, what kind of power gains would i be looking at by just swapping a ho intake manifold? anything else i could do cheaply while im gonna be in a yard for power??
Tuesday, May 23, 2006 2:09 AM
hey if any of you guys can find me a tranny down there at harry's for cheap im in need of a manual 2.4 isuzu =) ill pay yah to get it for me.
