OMG TPS sensor 2200 - Maintenance and Repair Forum
OMG TPS sensor 2200
Friday, May 12, 2006 11:45 AM
First off, I want to thank GM for using the cheapest, softest, fastest rusting metal they could get their hands on ...
Ok I'm in the middle of changing my TPS because it acted up pretty bad again. The 2 hex nuts that are holding the sensor against the TB were very rusted, so the first thing i did was spray some unlocking fluid or whatever to loosen them up, but that didn't help. Anyways, I got the right size hex key and the very first turn of the hex key, stripped the nuts perfectly smooth. I can not do anything for the life of me to get anything it the hole that will bite the hex nut and break it loose. Any help???
Re: OMG TPS sensor 2200
Friday, May 12, 2006 11:57 AM
Here is a pic of the screws on the sensor, notice how shiny the inside of the bolts are. How lovely.
Friday, May 12, 2006 12:56 PM
Awww geez thats sucks man, Heya BlackyK, Theirs a tool on this link that extracts the stripped screws out of it place heres the link.
http://www.sears.com/sr/javasr/product.do?cat=Mechanics+Tools&pid=00952816000&vertical=TOOL&subcat=Taps+%26+Dies&BV_UseBVCookie=Yes
Ive use several tools like this worked like a charm.
Good Luck dude
Friday, May 12, 2006 1:04 PM
Good Luck dude
Friday, May 12, 2006 1:08 PM
Either the above mentioned tool or I have used vise grips on rounded out allen head bolts but it looks like you might not have enough room to use those.
Rob
Sold 2/2/05
Friday, May 12, 2006 1:11 PM
their are shorter bits you can use, I just use a pair of need nose vise grips.
Friday, May 12, 2006 1:17 PM
How does that work? I think I might have something like that out in the garage.
Friday, May 12, 2006 1:19 PM
rich weeks wrote:their are shorter bits you can use, I just use a pair of need nose vise grips.
I tried vice grips, but they kept snapping off the side of the nut.
Saturday, May 13, 2006 12:00 AM
you need a bit that has a knotch in it, The bit is called screw extractor it looks like a torx bit.
Heres a link youre ya. http://www.mytoolstore.com/hanson/extractr.html
good luck
Saturday, May 13, 2006 2:33 AM
the one in the picture is also good.
Gilles
2.3 Ho
