if I have this2.3 quad 4 that came out of a olds. could I use it in a 95 cavalier??? the wireing harness doesn't need to be changed does it if its just replacing the engine??? I'm finding this sorta hard to believe? I"m almost positive that you can use it. its the same engine...
**changes are here**
If it's not a Z24 it doesn't have a 2.3 in it. Also, the PS pump is not exactly the same. The Ho engine is different too from the 95.
Gilles
2.3 Ho
