Hey gang. I got some codes I would like info on if you please. I have another thread in regards to a problem i have been working on with fuel delivery problems.
Car wont start.
Best I can tell you is it looks like i may have an electrical problem, but the car stutters when accelerating, but then will do ok after a point in the power band. For a few months the car wouldnt start at all, no power to the fuel pump and yes all the fueses ane relay were fine.
Here are the codes. Compliment of the local Advance Auto Parts.
DTC (codes)
P0107
MAP/BARO
Circuit Low Input
P0405
EGR Flow
Sensor A
Circuit Low Input
DTC Pending (Codes)
P0121
TPS/Pedal Position
Sensor A
CKT Range/Perf
P0405
EGR Flow
Sensor A
Circuit Low Input
Avoid some piddle-dicking and hair pulling and replace the EGR valve, throttle possition sensor, and MAP sensor. If you have access to a scan tool that lets you see real-time operation, hook it up and see how these sensors are (mis?)behaving.
