Ok guys. I got a pulling problem. After heavy braking, the car pulls to the left. I have 110,000 mi. on it. I changed the following; rotors, calipers, the brake fluid and flexible brake lines. It is still pulling. I used the hand brake to stop in the garage while the pull was still there so I could pull the wheel and see if there was any indication of the problem. Nothing visual appeared. When I tried to remove the caliper(the new one), i had to pry it off. Could my proportioning valve have some contaminates in it? I am at a loss. I changed everything I mentioned on driver and passenger side. Any help or suggestions would be great.
Check the left weel, left CV joit... proper aligment this guys may diagnose it
Ok, thanks. I will give it a shot.
No go. Thanks for input though.
