I was wondering if anyone has ever had a problem with the gasket in between the oil case and the motor leaking oil. I have the 2003 ecotec and it has about 46,000 miles on it and i am leaking oil right out of that gasket. Just wondering if anyone else has had this problem. Thanks a lot.
JIMMY
2003 Silver Cavalier 2.2L Ecotec!!!!
Sounds like the oil pan gasket. Did you check all the bolts to make sure none have backed out?
plugged pcv valve/ system may also cause that leak...
