Ok here is the deal....2001 Cavy sedan 2200. The outside temps are getting warmer.(well in buffalo that doesn't mean much) Over the past 2 days the cavy hasn't been starting the same, just alittle rough. Im due for an oil change. Could that be it or something else major starting? Thanx!!!
Stock or not.....It's Still a J !!!
Well Freddy-O :
what kind of syptoms are happening, When turning the key the engine struggles turning over?. Could be youre battery has a weak cell starting to fail. Simple digital multi meter will let you figure that one out. Youre starter could need replacing, Could have a weak or wornout soloide switch on the starter as well.
keep Us updated.
Good Luck.
yea..more details would really help
Well it turns over nice and strong started is working great. It spund like it gets choked up a little. But it only happens when I start she idles great and runs even better. My fuel pressure is fine at idle. maybe be my fuel pump might be starting to go??? And you can hear that lovely fuel pump prime when you turn th key on. Hmmm?
check your fuel filter.....could be kinda clogged up
Go Premium, it builds character!
