idle bad, acceleration bad - Maintenance and Repair Forum
Thursday, April 13, 2006 9:07 AM
I thought it was the ground on the battery tray, but it turned out that it wasn't. So now i'm stuck with the car idling at 1500-1800rpms and when i hit the gas even semi-hard the car will sputter and hardly accelerate. What would be causing these two things to happen? I know its related because last week I had the idle back down and the acceleration was perfect as well. Thanks for any help you give!
Re: idle bad, acceleration bad
Thursday, April 13, 2006 10:33 AM
Try cleaning the idle air control valve and throttle body with Gunk intake medic ($8) from your local auto parts store.
http://www.j-body.org/forums/read.php?f=11&i=105693&t=105600#105693
Thursday, April 13, 2006 10:52 AM
I agree it´s probably de iac valve... also clean the conector and contacts.
Thursday, April 13, 2006 12:01 PM
I know its on the tb but can someone tell me which one is?
Thursday, April 13, 2006 12:16 PM
It's at the front of the TB and it has 2 torx screws holding it in place. If you look at throttle body picture #4 on the link above it's at the bottom left of photograph.
Make sure your motor is off when you remove it for cleaning.
Thursday, April 13, 2006 1:40 PM
k, thanks.
Thursday, April 13, 2006 2:38 PM
it didn't fix my problem Mark, but hopefully it'll fix yours.
Desert Tuners
Thursday, April 13, 2006 4:36 PM
me either, i cleaned my IAC 3 times and my idle is still around 1500 rpm. Im thinkin that i have to get a new TPS, if that fixes my problem i will let u guys know.
Ill make a sig someday
Thursday, April 13, 2006 5:08 PM
When at a stop light, my car idles at 900 to 1000 rpm. When coasting down a hill with the clutch in, it idles at 1500 rpm. I feel like this is normal, but I could be wrong.
Is your idle always at 1500 or is does it fluctuate like mine?
Thursday, April 13, 2006 5:31 PM
mine idles at 1500, and when im coasting its around 1800-1900. its been doin this for quite some time now too. a few times over the winter when i released the clutch, the car decided to rev to 3000 and stay there (have no clue what that was all about), but im thinkin its a bad TPS. and Andrew, your car sounds perfectly normal, thats what mine used to do before how it is now.
Thursday, April 13, 2006 5:44 PM
It would be worth cleaning the TB first. You never know - it could be all carboned up and not closing properly. I have 155 k miles on my 99 Z24 and it's the original TPS.
Anyway, should you change the TPS also, it should be pretty easy. It's to the right of the IAC on the side of the TB (driver's side).
Best of luck.
Thursday, April 13, 2006 6:36 PM
The TPS is about $67 at a GM dealership. I changed mine out, but it didn't help. I also scrubbed my TB, especially where the butterfly meets the sides, and all of the holes used for vacuum. I tried a MAP and IAC sensor too, but that didn't help either.
you might try this:
when the car is idling, take some brake cleaner or carb cleaner and spray around the intake mani and injectors and see the RPM's drop. that's what happened on my car. I'm suspecting a leak around the injectors. I haven't had a chance to replace the o-rings yet, but I'm going to soon.
Desert Tuners
Friday, April 14, 2006 5:12 AM
^^ good info, im gonna go out and clean the TB right now, well see how that works.
Friday, April 14, 2006 6:01 AM
Mark - The cause of ur problem may be ur alternator. when i had my camaro and the alternator died, it had the same symptoms as your car does right now. You may want to have it checked, i think AutoZone can test them.
As for my problem, i just cleaned out the TB, and nothing changed. Then i sprayed the TB cleaner around the injectors, manifold, and TB, the rpm's didnt drop, so i dont think there is a leak. Looks like im replacing the TPS.
Friday, April 14, 2006 7:19 AM
A bad alternator usually turns a battery light on (dash), your gauges/accessories slowly give out , then your motor revs to compensate for the loss of power. That was my experience last summer.
